Simon
| posted on 10/3/06 at 10:57 PM |
Rover V8 SD1 EFI loom
As title says.
or can I use something else?
Please
Simon
[Edited on 10/3/06 by Simon]
AdamR
| posted on 11/3/06 at 12:10 AM |
If its just the EFI loom you're after and you're looking for something 2nd hand, you have options from Land Rover too. I'm assuming
the loom for pre-95 flapper EFI used on the Discovery and Range Rover is the same as the SD1 flapper version or could easily be adapted. I've no
idea how similar the later hotwire loom is.
Which type of EFI are you planning to use? I have a flapper system from a 3.9 Disco.
Simon
| posted on 11/3/06 at 08:17 PM |
Adam,
Plan is to get a complete SD1 EFi up an running, so needall bits for that.
So far have manifold/ram pipes/fuel rail and need plenum, loom and ECU.
Want to get fi up and running, then over winter go to megasquirt with one or two turbos.
Simon
Andybarbet
| posted on 12/3/06 at 11:50 PM |
Weve got an almost complete wiring loom for a Rover SD1 2600se. Y reg car,not sure if this would do you ?
If its any use to you let us know,its been hanging up the garage for a few years and would be nice to be put to good use.
We also have all the black boxes from the same car if any use to you or anyone else.
Regards.....Andy
[Edited on 12/3/06 by Andybarbet]
AdamR
| posted on 13/3/06 at 06:28 AM |
Simon,
Have you seen
this item on
ebay? I paid over 100 quid for the 3.9 equivalent, so looks like it might end up a good deal (or I was ripped off - possibly more likely).
(also sent you a U2U as there is only a few hours left on the auction)
Adam
[Edited on 13/3/06 by AdamR]
Simon
| posted on 13/3/06 at 07:55 PM |
Adam
Unfortunately I missed it - finished about 4 hours ago
Never mind
Simon
