James
posted on 13/3/06 at 12:59 PM |
Pinto exhaust flange template
Anyone got an diagram (acrobat .pdf or otherwise) I can use to make an accurate template for a Pinto exhaust flange?
Much gratitude would ensue!
Thanks,
James
- Muhammad Ali
timf
posted on 13/3/06 at 02:55 PM |
dxf in the zip file
A prisoner of war is a man who tries to kill you and fails, and then asks you not to kill him."
- Sir Winston S. Churchill, 1952
Danozeman
posted on 13/3/06 at 05:09 PM |
Could not get a gasket and make one from that?
Dan
posted on 13/3/06 at 07:51 PM |
Pinto exhaust gaskets come in four pieces so no good, hammer and cardbourd works a treat . Never used the double sided tape though
timf
posted on 14/3/06 at 09:00 AM |
james
jpegs as requested
ext_flange1
and
ext_flange2
James
posted on 14/3/06 at 10:53 AM |
Thanks Tim and thanks for the advice on making a template Calvin.
Will set to ASAP.
James
- Muhammad Ali
