Danozeman
| posted on 21/3/06 at 04:33 PM |
Longer Cortina wheel studs.
Does anyone have any longer cortina wheel studs kicking about? I need 16. Iv got cortina front hubs and cortina back axle. Also need matching
nuts.
or
wheres the cheapest place to get them from and what thread etc are they?
[Edited on 21/3/06 by Danozeman]
Dan
big_wasa
| posted on 21/3/06 at 04:46 PM |
Standard Ford part Dan .Couger, Mondeo, all the same.
| posted on 21/3/06 at 04:48 PM |
Sierra fronts are a bit longer
But for longer studs Yukspeed is a good source.
Deckman001
| posted on 21/3/06 at 04:51 PM |
rally design do wheel studs, try them
Jason
| posted on 21/3/06 at 04:53 PM |
M12x1.5 aren't they
They usually run at around £1.50 ech on ebay, Fisher Sports Cars have some on there now.
Check it
out.
bob
| posted on 21/3/06 at 05:02 PM |
These any good
http://cgi.ebay.co.uk/16-Ford-metric-wheel-studs_W0QQitemZ8048104984QQcategoryZ72257QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
liam.mccaffrey
| posted on 21/3/06 at 06:08 PM |
i went to the scrappy and got em for £3 and half an hour
Build Blog
Build Photo Album
Danozeman
| posted on 21/3/06 at 06:48 PM |
Excellent. Cheers chaps. How long have most people gone for?
Ill have to decide where to get them from now..
Dan
highspeeddirt
| posted on 21/3/06 at 07:01 PM |
One thing to watch for with these aftermarket studs is the longer shoulder area. I found that my RS2000 wheels with the flange nuts bottomed out
before the wheels were tight. At the front I had to swap them for original Sierra studs and I've fitted a 3mm spacer to the rears. The fronts
are worse because there is no drum or disc fitting over the studs before the wheel goes on. If you are not fitting spacers I'd stick with Ford
studs for the fronts.
Danozeman
| posted on 21/3/06 at 10:23 PM |
I'd stick with Ford studs for the fronts.
I think with my wheels on the stud will take about 2 threads of the nut.
Dan
highspeeddirt
| posted on 22/3/06 at 06:13 AM |
I meant the longer Sierra studs. If your wheels have a thick centre then you should be okay with the aftermarket studs.
| posted on 22/3/06 at 11:53 AM |
where did my post go?
that's right; I got some from RD but really wanted standard ones (should have tried Ford) ... but anyway I turned them down using a drill and
angle grinder then continued the thread with a die.
When you fit them, use a wheel as a puller by doing up the wheel nuts. If you use a vice to press them in, they may not go in straight so the wheel
won't fit, ask me how I found that out
