darrens
| posted on 4/4/06 at 06:18 PM |
Granada 7.5" Diff Long Bolt
As above, need the long bolt for the 7.5" diffs, anyone got one going spare.
ned
| posted on 4/4/06 at 06:20 PM |
i believe you can use studding as an alternative - available from any DIY store.
Ned.
beware, I've got yellow skin
bob
| posted on 4/4/06 at 07:19 PM |
DIY store studding probably wont be high tensile, in fact probably not even preper thread but moulded rubbish.
bob
| posted on 4/4/06 at 07:21 PM |
If its the top of the diff bolt i used two M12 hex head bolts and fed them through from the inside.
Kissy
| posted on 4/4/06 at 08:59 PM |
I got one. FoC + Post.
amalyos
| posted on 4/4/06 at 09:47 PM |
Screwfix do Stainless Studding. Thats what I've used.
nludkin
| posted on 5/4/06 at 08:09 AM |
I second bob with the 2 M12 bolts approach. It works a treat, although a tiny bit of metal needs grinding off of the nut that fits inside the diff
casting.
ned
| posted on 5/4/06 at 08:25 AM |
using capheads from the centre pointing outwards should required no grinding i'd of thought surely?!
bob
| posted on 5/4/06 at 08:36 AM |
Yup cap heads no grinding
Bolts maybe a tad
