tom windmill
| posted on 16/4/06 at 10:37 PM |
ZX9 std air box
HI,
i am going to be fitting ZX9 carbs to pinto and i am looking to fit an air box so i am looking for a std ZX9 air box to modify for my needs.
Thanks Tom
| posted on 16/4/06 at 11:20 PM |
bugger, i threw one out the other day. Might still have it at the bottom of the bin. Are you sure it will fit under your bonnet?
| posted on 17/4/06 at 08:31 AM |
I had to cut mine and turn it round on it's base. The intakes would have been over the side rail where my engine is fitted. On a pinto it will
be 4 feet high.
[Edited on 17/4/06 by Peteff]
mark.s
| posted on 17/4/06 at 09:51 AM |
Tom ive got one here if Joels bin man has been
tim windmill
| posted on 17/4/06 at 09:54 AM |
i only really need it for the ram pipes the rest i intend to butcher to try and make it fit if not i will get a susage filter
| posted on 17/4/06 at 11:11 AM |
its your lucky day, i found it! You have u2u.
by ram pipes, do you mean the front pipes off the air box or the actual tubes that sit on the carbs? I dont have any spare tubes, just airboxes.
[Edited on 17/4/06 by JoelP]
