Author: Subject: Heat Shield
muzchap
posted on 26/4/06 at 09:48 AM Reply With Quote
Heat Shield
Hi guys,
I need some heat shield plate - and don't want to pay the earth.
It's to protect my starter motor and engine mount rubber - I'm trying to deflect the heat away - wish I had a pic to show you.
Or would I have better luck in a scrappy?
Murray
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
bernie955
posted on 26/4/06 at 10:06 AM Reply With Quote
Get a scrap piece of stainless and make one. Give it a polish and it should work OK. Failing that a lot of the latest insulation products used for stereo installations in cars are also good heat insulators. Check with an installation centre for some scraps maybe.
Kissy
posted on 26/4/06 at 10:23 AM Reply With Quote
I have some non-adhesive 0.2mm corrugated ally heatshield, appx 600mm sq.
Deceptively stiff due to the corrugations in all directions, but usefully maleable. I can drop off at Intier Automotive in Tachbrook Park, Warwick, or you can collect from Redditch (weekdays for both)
I also have some s/a ally heatshield on a roll ('kin loads actually) I can cut you off a metre or so. Same arrangement as before.
muzchap
posted on 26/4/06 at 10:58 AM Reply With Quote
Kissy,
You're a legend
I work in Southam - but can drive to meet you. I don't know how far 'Redditch' is from me?
I'm available all week - and would probably take both options if that's ok. Just let me know how many beer tokens you require
