wilkingj
| posted on 27/4/06 at 03:06 PM |
Roller Door Wanted
I need a Roller Shutter Door.
3m (ish) wide and 2.5m high or higher up to 3m.
I've got to demolish a wall to get the Viento out for the Mot / SVA, so need to fill the hole.
Any suggestions welcome as to other methods of filling the hole / securing the shed.
Best Regards
Geoff
http://www.v8viento.co.uk
stevebubs
| posted on 27/4/06 at 03:20 PM |
Waterfall like in Batman!!!
stevebubs
| posted on 27/4/06 at 03:21 PM |
Use jet washers to create the streams of water...no fecker will get through that without having their skin shredded
| posted on 27/4/06 at 04:42 PM |
A pair of gates.
Angle iron frame filled in with planks or ply board. Drill through the angle where they butt together and padlock them, 5 good locks should do it then
grease across the tops.
ruudbeckers
| posted on 27/4/06 at 06:05 PM |
Can't you take the Viento apart and rebuild it outside?
| posted on 27/4/06 at 07:02 PM |
Geoff, there is a garage door advertised in tonights Cambridge Evening News . Think it might be in Haverhill area tel no 01440 713443 . May also be
worth checking the yellow free ads paper . Any news on SVA date yet? NTDWM
