Author: Subject: edis 4 bits
DarrenW
posted on 30/4/06 at 08:50 PM Reply With Quote
edis 4 bits
Im after a coil pack, ignition leads, crank sensor ( i have wiring) and trigger wheel so i can fit megajolt to my Pinto. My megajolt ECU has built in Edis module so done need that bit. I dont need any wiring or plugs as i have a megajolt loom.
DarrenW
posted on 1/5/06 at 09:42 PM Reply With Quote
Ive just won a coil pack and leads off ebay (£14).
Still need crank sensor and trigger wheel.
I can get trigger wheel off Ford or from triggerwheels.com so will be £20 tops. Not the end of the world.
Sensor will be appreciated (ive seen the one on ebay so watching it closely).
posted on 1/5/06 at 09:45 PM Reply With Quote
Need anything off my Sierra Darren? I've stripped it right down now.
Managed to knacker the passenger side upright though after snapping the bolt that holds it to the damper! Bugger!
Are yuo in any night this week? Like to come over and have a butcher at your car.
DarrenW
posted on 1/5/06 at 10:41 PM Reply With Quote
i dont think your ierra will hve the crank sensor or triger wheel unless it is a CVH??? If it is the crank pulley (36-1 teeth) might be useful.
Yes i will be probs every night. Gearbox oil leak to fix (spare type 9 box might be useful if it i sdry).
