flak monkey
| posted on 14/5/06 at 12:14 PM |
Fuel Pump
Need a fuel pump suitable for feeding my twin 40s. Dont think the std one is up to the job, so will need an electric one. One similar to this is what
I need I think:
Clicky
Thought I would try my luck on here and see if anyone had a spare one kicking around...if you do, let me know!
Sera
http://www.motosera.com
Stuart Walker
| posted on 14/5/06 at 03:15 PM |
Yep, that's the one I'm using... Along with a filter king to set the pressure up correctly for the carbs.
DIY Si
| posted on 14/5/06 at 05:16 PM |
I'll be using a pair of morris minor pumps if my standard pump isn't up to it. Correct pressure already and cost £15 for both. Can also be
mounted just about anywhere.
