andyw7de
| posted on 19/5/06 at 09:43 PM |
Rubber brake hoses
looking for a source for the rubber hose that connects remote resevoir to master cylinder.
Does it need to be special stuff for brake fluid and marked as such or can I use fuel pipe ?
RazMan
| posted on 19/5/06 at 09:46 PM |
Definately has to be the cotton braided special stuff or it will fail SVA.
Your local hydraulic shop will stock it and give you a spec sheet to convince Mr SVA.
Raz
muzchap
| posted on 19/5/06 at 10:29 PM |
If not - Merlin Motorsport can sort you out
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
RichieC
| posted on 20/5/06 at 06:48 AM |
I used stainless braided hose for the reservoir to cylinders and it turned out to be Sytec FH013 inside (which is the red cotton braided stuff).
Not all fuel lines are compatible with brake fluid though so beware of that, FH013 is and heres the spec sheet.
Rgds
Rich
Johnmor
| posted on 20/5/06 at 09:19 AM |
Hose
The hose used to supply the brake matser cylinder from the reservoir should be marked with a standard.
Eg. Din 73-379bB
suitable for lead substitute/Unleaded, brake fluid(low pressure) diesel/water/Air.
This is a common standard for low pressure fuel lines.
High pressure fuel hose is Din73379E and is not suitable for brake fluid
Try fuelsystem.co.uk
