raymonddaf
posted on 5/6/06 at 09:48 AM |
Aluminium Plate 0.5 - 0.7mm required
Anyone know where I can get alu sheet for the inside of the dash. I need 1000mm x 200mm x 0.5-0.7mm thick.
I have tried ebay with no luck, though i have e-mailed a few of the ebayers selling other sizes.
Most companies i call however want me to buy a minimum size, 1000mm x 2000mm which is way to much. Any help much appreciated.
se7ensport
posted on 5/6/06 at 12:38 PM |
try car builder solution on 01580 891309 they will cut to size and post, worth checking P&P cost before ordering.
cheers
alex
posted on 5/6/06 at 02:34 PM |
B&Q do ali this thin, 0.5 mm, 3 sizes, the largest sheet may be 1 m long. It is quite pricey, from memory about £ 30 but no postage if you have
one nearby.
You realise you need some backing as that is very thin stuff.
