Author: Subject: in line thermostat temp sensor
graememk
posted on 7/6/06 at 08:13 PM Reply With Quote
hi my donor engine (nissan 1.8t) has 3 built in temp sensors but all of them report utter boll0x to my MS 138f cant be correct so i'm going to use a inline one before the rad but wheres a good place to get one ?
many thanks
graeme
the_fbi
posted on 7/6/06 at 08:29 PM Reply With Quote
best vfm afaik, they do different sizes too.
Clearly you still need a sender though.
Linky
[Edited on 7/6/06 by the_fbi]
muzchap
posted on 7/6/06 at 08:34 PM Reply With Quote
Graham,
You want one of these:
From here CLICK ME
Bout £35 delivered I think...
[Edited on 7/6/06 by muzchap]
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
graememk
posted on 7/6/06 at 08:42 PM Reply With Quote
thermostats working fine but i cant get a reading on the temp gauge.
muzchap
posted on 7/6/06 at 09:00 PM Reply With Quote
Oops - misunderstandy! Get one like the_fbi says and any ford sender!
I actually have a spare somewhere you can have?
I'll try and find @ the weekend
paulf
posted on 7/6/06 at 09:18 PM Reply With Quote
A blue Bosch sensor as fitted to vauxhalls peugots etc works well and is near the correct value without changing the bias resistor.Ford senders are near to 27k at room temp, Bosch and the correct GM ones are about 3k I used a 2,4k bias resistor and bosch sensor and it is within a few degrees of correct temperature.
Paul
graememk
posted on 7/6/06 at 09:35 PM Reply With Quote
so you think my sender in the car is ok and just needs a resistor putting inline ?
posted on 8/6/06 at 08:35 AM Reply With Quote
it may.
I did this to mine - smiths(?) temp guage plus Ford temp sender - needle would point past Norm when engine is up to temp (at idle and fan comes on) so I put in 33 ohm in series to keep needle at N.
the theory being if needle goes past N, then I worry
