Author: Subject: Wheel Studs
RoadkillUK
posted on 28/6/06 at 12:18 PM Reply With Quote
Wheel Studs
Hi all, I'm looking for a place local(ish) to me that sell wheel studs for a standard Ford Escort MKII rear axle.
They are M12x1.5 and I'm in Bradford.
I just got some delivered this morning and the shank is too long (not enough of it threaded).
Help Pls asap
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
Hammerhead
posted on 28/6/06 at 12:24 PM Reply With Quote
ebays not bad for studs or burton power
Tinks
posted on 28/6/06 at 12:47 PM Reply With Quote
Try S & J Motor Factors on Manningham Lane
Tel 01274 723027
posted on 28/6/06 at 12:48 PM Reply With Quote
yep, it a right bugger; loads of peopl sell lnger studs but I;ve yet to find standard length.
What I did was stick them in a drill press and whislt they are whizzing round, use an angle grinder to "turn" them to the correct diameter and then using a die, cut the threads.
carlgeldard
posted on 28/6/06 at 01:22 PM Reply With Quote
Send me a U2U as I have 16 at home in Wakefield. They might be what you want.
Carl
[Edited on 28/6/06 by carlgeldard]
RoadkillUK
posted on 29/6/06 at 01:36 AM Reply With Quote
Cheers Tinks, I've tried S&J with no luck. Cheers Carl, but they are too long (shank).
Here's what I'm after ... the one on the right, the shorter one (x8).
Escort Rear Studs
Escort Rear Studs
Roadkill - Lee
www.bradford7.co.uk
carlgeldard
posted on 29/6/06 at 06:27 AM Reply With Quote
Never seen any like that before.
Carl
John Bonnett
posted on 30/6/06 at 05:06 PM Reply With Quote
Looks like it may have been shortened.
John
posted on 30/6/06 at 06:15 PM Reply With Quote
Burtons. Fairly cheap and quick delivery, good advice on the phone.
RoadkillUK
posted on 1/7/06 at 10:34 AM Reply With Quote
Hi all again
The studs are original 1978(ish) Escort MkII.
I have tried many places and you just can't get them. It isn't a problem unless you are using these spacers, because of the thread,
which we were, the problem is that if you don't tighten the extenders properly then after several hundred miles you end up with 3 snapped studs like we did I say 3, We've not checked the other wheel, it's against the wall atm.
Anyway, I've found a PLACE in Scarborough who sell plenty of spacers and studs etc.
£20+postage for 25mm spacers AND 8 longer studs, just awaining delivery.
Oh, and thanks for the help
[Edited on 1/7/06 by RoadkillUK]
Roadkill - Lee
www.bradford7.co.uk
