Mojo Pete
posted on 13/8/06 at 08:05 AM |
Build Stands
Wanted - pair of Build stands for Sylva Mojo.
Near Bristol would be good.
Moving house this week so please contact on 07887-565036
Humbug
posted on 13/8/06 at 09:15 AM |
If you're quick (and close enough) here is a build trolley for free... looks like someone else has first dibs, though
http://www.locostbuilders.co.uk/viewthread.php?tid=49525
ned
posted on 13/8/06 at 10:10 AM |
I built my locost chassis up (with iron block 2ltr engine in it) on homebase/b&q plastic sawhorse a-frame type trestles that were about a
tenner.
when it got heavier i put the two trestles under the back and my workmate (9.99 b+q) under the front. not had any problems. and i could still climb
into it carefully to sit down and make brum brum noises..
Ned.
[Edited on 13/8/06 by ned]
beware, I've got yellow skin
Aboardman
posted on 13/8/06 at 10:24 AM |
i just used 4 axle stands.
wilkingj
posted on 13/8/06 at 10:58 AM |
Talkabout Lightweight stands!... As I was building the heavier Viento, I built a trolley / stand out of 75x100x9mm Angle. Mind you it was free
ironwork (very locost) and all I had at the time. It will support most things I want to put on it.
Best Regards
Geoff
http://www.v8viento.co.uk
COREdevelopments
posted on 13/8/06 at 12:28 PM |
im using 3 axle stands, suprisingly quite stable at the mo, the car is practically together,
i did buy 2 clarke trestles but the were way too high and i would of had trouble getting the car off them,
however i would sugest using a builld platform of some sort, like the others have said some cheap trestles or workbenches as the problem of axle
stands is that the car sits too low which will kill your back. even i get a bit of a bad back and im only 23!!
lsdweb
posted on 13/8/06 at 01:04 PM |
Two B&Q saw horses and my engine crane to lift it up and down.
Picture here
Regards
Wyn
DaveFJ
posted on 13/8/06 at 03:29 PM |
I just knocked up a couple of trestles out of some scrap 4x2 that I found in a skip.....
Dave
