Author: Subject: rv8 efi unit wanted
froggy
posted on 29/8/06 at 03:56 PM Reply With Quote
rv8 efi unit wanted
efi unit for rv8 flap or hotwire , loom and ecu not important
Paul (Notts)
posted on 30/8/06 at 06:32 AM Reply With Quote
May have ( will have to check other half has not got rid of it ) the intake manifold upwards off a 3.5 if you want it - will check later today inc injectors.
if so its yours if you want it..
Paul
Its still in the shed! so if you are after any of the following its yours..( too big to post but could take it to donnington!)
Rover V8 3.5 EFI system
Condition looks OK but I AM NO EXPERT!.
Bits
inlet manifold and Plenum chamber along with the flapper airflow meter from a 1988 3.5 land rover automatic. Includes water rails not shown in picture.will need cleaning and some carbon deposits removing from inside chamder. Injectors are all there but may need new rubber tube to connect to fuel rail as they look a little cracked.
[Edited on 30/8/06 by Paul (Notts)]
