blockhead_rich
| posted on 4/9/06 at 08:17 PM |
Ford coil pack wanted
Just wondered if anyone has a spare ford coil pack that they want to exchange for beer tokens? I think one from any Zetech engined car will do the
job.
My current one has the following number(s) on it if this helps identification;
928F-12029-CA (top) and 0277A (bottom).
(I'm using it on my 4AGE + Omex and I'm getting a miss-fire on # 4 cylinder @ idle only, so I'm just trying to rule out all possible
causes + I'll have a spare if it's not the cause of my actual fault).
Cheers in advance.
Rich
wilkingj
| posted on 4/9/06 at 08:30 PM |
Which ever one you get, make sure you get the right leads to fit it, as there are different fittings for the HT lead connections.
Best Regards
Geoff
http://www.v8viento.co.uk
blockhead_rich
| posted on 4/9/06 at 09:08 PM |
Thanks Geoff - I have had to "butcher" the standard 4AGE ones to fit but they give a spark so I'm hoping this isn't my
problem.
Rich
stevebubs
| posted on 4/9/06 at 09:10 PM |
if it's only on #4 then swap the connections between #1 and #4
blockhead_rich
| posted on 4/9/06 at 09:23 PM |
Good idea Steve - hadn't thought of that - doh, I'll try it tomorrow!
UncleFista
| posted on 4/9/06 at 10:23 PM |
Don't you just love lateral thinking ?
Tony Bond / UncleFista
lsdweb
| posted on 5/9/06 at 01:13 PM |
Rich
I've got a brand new one going spare if you still need one. Sadly, one of the mounting lugs snapped off when it was being delivered to me but
apart from that it's perfect.
Regards
Wyn
lsdweb
| posted on 5/9/06 at 01:15 PM |
Rich
Regards
Wyn
blockhead_rich
| posted on 5/9/06 at 08:07 PM |
Wyn - thanks for the offer.
I'll let you know if I need it as I had another play tonight following the ideas of yesterday, and I can't seem to phathom what's
going on. It appears I have a problem with No. 4 cylinder only and not to do wiht the coil pack or ignition leads or the plugs. So not too sure if
it's an Omex set up issue. So I'll probably have to get back in touch with LPS in Ipswich - the Rolling road guys.
Rich
lsdweb
| posted on 6/9/06 at 04:16 PM |
Best of luck Rich!
