D Beddows
| posted on 12/9/06 at 01:27 PM |
Crossflow Tubular Exhaust manifold
I'm after the above, not bothered about it being stainless/over the top rail/through the body etc - would prefer 4 into 1 but 4 into 2 into 1
would do the job...... what I don't want is some bodged together homemade looking attempt
Does anyone have one they want rid of or alternatively who sells the cheapest at the moment? - I don't want to spend loads as it's only
going to be used to get the car SVA'd with a crossflow before fitting something more modern
boxfile
| posted on 12/9/06 at 01:53 PM |
I have a mild steel 4-2-1 westfiled one which I'm about to replace with a 4-1 stainless manifold should be coming off in the next few days if
your intrested.
I also have a modified R1 exhaust can and stainless link pipe to go with it.
but wouldn't it be cheaper to just use a stock cast iron manifold and get a pipe bent up at an exhaust place to suit, as its only for SVA.
I am not a number!
trextr7monkey
| posted on 12/9/06 at 03:12 PM |
We have several standard cast manifolds knockin about if needed, Could take to Donington if it helps
D Beddows
| posted on 12/9/06 at 03:52 PM |
U2U sent Boxfile
