lightspear27
posted on 18/9/06 at 08:01 AM |
Corner weight - suspension set up and check
Hi, quite the same question as the one under but regarding suspension check and set up, corner weighting, ...
... where in the south between Dover and London?
What price should I expect?
Even better ... do you know of a place where they do rolling road session + corner weighgting / suspension set up?
Thanks,
Stefano
procomp
posted on 18/9/06 at 08:16 AM |
Hi dont personaly no of any one in that area but there must be someone.
Price wise should be looking at about £200 for a full setup inc all the cambers checked and set- tracking f+r set depending on irs or live axle-
castor checked and adjusted if adjusable- ride hieghts set to suit what use and what the car requires- corner weighted- and if they have the facility
all dampers removed and checked on the dyno.
cheers matt
Edit to say that rolling road costs would be on top of that.
[Edited on 18/9/06 by procomp]
RazMan
posted on 18/9/06 at 10:42 AM |
I was charged £180 for the geometry setup and about £40 for corner weighting.
Raz
lightspear27
posted on 18/9/06 at 11:02 AM |
where in the south can I go for a complete suspension set up?
RazMan
posted on 18/9/06 at 11:13 AM |
Mine was done at Aeon Sportscars They are near Maidstone if that is any good for you. Ask for John Hewat
[Edited on 18-9-06 by RazMan]
Raz
lightspear27
posted on 18/9/06 at 11:32 AM |
Hi Raz, do you think they accept to set up the suspension on a "non-aeon" car?
RazMan
posted on 18/9/06 at 11:41 AM |
No problem - when I was getting mine done he was just finishing a Fisher Fury. He has some very good lazer equipment and is a knowledgable chap so I
am confident he will sort you out.
Raz
