Author: Subject: 16mm to 22mm coolant hose
the_fbi
posted on 24/9/06 at 09:18 PM Reply With Quote
I don't suppose anybody knows of a standard coolant hose which is 16mm to 22mm (ID) and at least 30cm long?
Going to look a bit messy using a 22-16 reducer and a 16mm length, so don't really want to.
omega 24 v6
posted on 24/9/06 at 09:46 PM Reply With Quote
Just a quick thought but a std plumbers solder ring fitting 22mm to 15mm reducer might just be the thing your looking for. Unless you meant you didn'y want to use a reducer at all (i.e.only a pipe)
A fitting like thisreducer
[Edited on 24/9/06 by omega 24 v6]
the_fbi
posted on 24/9/06 at 10:03 PM Reply With Quote
Nice idea, but unfortunately I need to go from a 22mm male on the header tank, to a 16mm male on the bottom collant pipe.
So I'd still need 2 pieces of coolant hose with the copper jobby.
Nice to know that exists for the future though!
ta
Chris
craig1410
posted on 25/9/06 at 11:36 AM Reply With Quote
You can get these reducers with a mixture of male and female ends. It might be worth taking a bit of rubber hose down to your local DIY store and see if you can find a solution. I needed something similar to bypass the heater pipes on my Rover V8 engine. I ended up using a 15mm to 22mm reducer, a 22mm 90 degree elbow, a 15mm 90 degree elbow and a little bit of copper pipe. Did the job nicely!
Craig.
the_fbi
posted on 25/9/06 at 06:17 PM Reply With Quote
Originally posted by stuart_g
Have you tried anywhere like Samco, they would surely be able to make you one or may even have one, not sure how much they would charge though.
Samco/SFS etc can certainly make them, but they are expensive.
An off the shelf jobbie would be sub £5, just need to find one.
I'll take a trip to the local factors to see if they've got a nice few shelves to look through.
