Agriv8
posted on 13/10/06 at 07:35 AM |
Rover 4.2 pistons Required
A real long shot but I dont suppose anbody on here knows the wearabouts of some second hand 4.2 pistons. 1 required Minimum but anything
considederd.
required because I had a very senior moment yesterday.
Regards
Agriv8
graememk
posted on 13/10/06 at 09:46 AM |
come on what did you do, will you be voting yourself dunce of the week ?
Agriv8
posted on 13/10/06 at 11:22 AM |
Nope Not saying !!!!!!!
as its really, really Silly and I woud not just get dunse of the week probably manth and year would be easilly acheivable.
Regards
Iain
stevec
posted on 13/10/06 at 01:59 PM |
This guy may be worth a ring,
JE Developments
Claybrooke Mill
Claybrooke Magna
Nr. Lutterworth
LE17 5DB
tel: 01455 202909
John Eales is the proprietor of J.E. Developments. Do not confuse this company with J.E. Motors as many people do. John probably knows more about
tuning the Rover V8 than anybody else in the UK. He has prepared many successfull competition engines including the engine in Tim Coventry's
devastating hillclimb SEiGHT.
Agriv8
posted on 13/10/06 at 02:42 PM |
Thanks Steve,
will fire an email off to him tonight. JED did my Getrag to V8 bellhousing when I picked it up he was running a 5ltr monster on 4 downdraghts up on
the dyno. Bl**dy impresive bloke.
Agriv8
jollygreengiant
posted on 13/10/06 at 04:31 PM |
Broke a piston skirt while holding it in a vice?
OR
Dropped somthing realy heavey on your pistons and damaged the skirts on some, at least one very badly.?
stevec
posted on 13/10/06 at 07:12 PM |
I used to work for John many years ago,
We used to have some laughs. And he can drive a bit as well.
Steve.
Agriv8
posted on 13/10/06 at 07:53 PM |
OR
if only - even worse than both of those infact worse both than those put together, self inflicted yes, acident yes piston knackered yes.
still not admitting my c*ock up
Simon
posted on 13/10/06 at 08:26 PM |
This any use
http://cgi.ebay.co.uk/TVR-CERBERA-AJP-4-2-CRANK-RODS-AND-PISTONS_W0QQitemZ120040592678QQihZ002QQcategoryZ108792QQrdZ1QQcmdZViewItem
Simon
Agriv8
posted on 13/10/06 at 11:03 PM |
dont think rover v8 and ajp v8 are interchangable.
i think his last sentance ....
THIS IS FOR AN AJP FLAT PLANE CRANK ENGINE, NOT, I REPEAT, NOT FOR A ROVER V8
but thanks anyway turbo manifolds lookgood by the wak
regards
agriv8
jollygreengiant
posted on 17/10/06 at 08:18 PM |
If it helps mate, many years ago I was rebuilding a vauhall 32v staight six. Bolted head down, started fitting cams. Bolted down nearside cam &
repeated process for offside cam, layed it down, layed down cam caps & did up finger tight then ran up and down caps tightening a little at a
time.
Just nipping up the last little bit ........ SNAP went the cam shaft. £400 form the dealers later.
Woops I'd got the cams fitted the wrong way round.
I just told the boss it must have been a brittle or weak shaft.
