Author: Subject: Stainless steel wool
posted on 16/10/06 at 09:20 AM Reply With Quote
I'm trying to find some stainless steel to use as the first layer in a repacked exhaust.
Trouble is, I'm trying to buy it in Ipswich, which really isn't the place to buy out-of-the-ordinary stuff...
So, can anyone suggest the sort of outlet I should be visiting? In other words, who uses this stuff and what sort of shop would they buy it from? I tried local plumbing supply shops, but all I got was a "dur..." response.
Today is likely to be the only nice day all week, so I want to get this silencer rebuilt so I can go out and drive...
Agriv8
posted on 16/10/06 at 09:54 AM Reply With Quote
B&Q sell it but usure of how much you would need for an exhaust or what size pack they sell. I am sure other DIY superstores stock somthing
It is usually with the paint preperation stuff ( its used for rubbing down wood before varnich / painting ) or between coats to provide a Key .
A good hardware store would be a safe bet but from your posts you seem to be short of them. Any good woodworking shop would be a good bet
regards
Agriv8
JohnN
posted on 16/10/06 at 10:10 AM Reply With Quote
Wire wool is commonly available, plumbers merchants would be the cheapest.
However, where you could get stainless wire wool, I don't know - but would be interested to hear.
Agriv8
posted on 16/10/06 at 10:16 AM Reply With Quote
OOppss - didn't See the 'Stainles' Bit
Never come across that variant well not in DIY shops anywhay
regards
Agirv8
DaveFJ
posted on 16/10/06 at 10:21 AM Reply With Quote
What does our Paul (907) use to pack his? probably worth a U2U ?
Dave
posted on 16/10/06 at 10:33 AM Reply With Quote
Spoke to him yesterday - he doesn't use it in his silencers.
It has to be stainless, otherwise it'll rust and burn away. It does exist 'cos it's in all the on-line repacking guides... it's just that I can't find any.
Kissy
I'm not sure whether s/s will behave any better than mild steel - if not it will be blown out on the first run. Just use the proper wadding - Powerspeed is Ashford, Kent can oblige, so can Merlin Motorsport and Demon Tweeks, but they ain't cheap
r3nuf
posted on 16/10/06 at 10:37 AM Reply With Quote
David, I have just spoken to New Gases on Martlesham Heath , thinking they might be able to help you.
No joy there though, they suggested a mail order company in Wales. But weren't anymore specific.
Cheers Gary
Drive Fast....Brake Late....Take Chances
DaveFJ
posted on 16/10/06 at 11:04 AM Reply With Quote
This is the stuff you want - don't know where would stock it though...
link
perhaps try the old 'send me a sample' scam ?
HTH
[Edited on 16/10/06 by DaveFJ]
Dave
DaveFJ
posted on 16/10/06 at 11:08 AM Reply With Quote
just found a supplier
link
not to expensive either
enjoy
Dave
posted on 16/10/06 at 11:34 AM Reply With Quote
There's a link to Milner's in the links section on the site
Phil.J
posted on 16/10/06 at 01:30 PM Reply With Quote
Just for info. Daryll Stanniforth Motorsport (yes, son of Alan) in Yorkshire sells it. Havn't got any contact info. in front of me at the moment I'm afraid.
Phil
stevebubs
posted on 16/10/06 at 02:10 PM Reply With Quote
got mine from Merlin...wasn't that expensive....
stevebubs
How much do you need, BTW - I still have most of the roll left...
zetec7
posted on 16/10/06 at 02:54 PM Reply With Quote
Around these parts, it's sold in grocery stores for household cleaning, pot-and-pans scouring, that sort of thing....cheap!
dunno muc habout this but know that wire wool burns quite nicely?
what about using those soft metal pan scrubbers? think those are stainless but much chunkier than wooland maybe not as restrictive?
paulf
posted on 16/10/06 at 05:19 PM Reply With Quote
I used some fine stainless gauze that I had lying around and secured it around the perforated tube with stainless tie wraps. This seems to have cured the problem that i had of burning the wadding away in a week or so.
I also found a good source of basalt wool, after I had packed mine with some that I had been given from an exhaust manufacturer I noticed a large roll off identical looking material in the skip at work . It turned out to be a fire blanket used to insulate a flue in the roof space and was brand new as left over. I removed it from the skip and now have enough to repack my silencer dozens of times.
Paul.
posted on 18/10/06 at 11:30 AM Reply With Quote
Had a fairly hysterical phone conversation with Wunoff this morning - I'd emailed a query, they'd responded, and I'd read it that they had it in 3 foot widths... odd, but fair enough. When I spoke he said that I'd probably need 2 metres to do the job - how much!?
Then I re-read the email... it comes in 3" widths, not 3'
Order placed, thanks for all the help.
BTW: I found a good site that explained why stainless wool was used - it's to prevent the erosion of the wadding by the hot gasses whizzing by, rather than to prevent burning. Although the exhaust gasses are very hot in the silencer, they shouldn't be hot enough to directly burn the wire wool. However, it does eventually get eroded by the gasses, just not quite as fast.
Schrodinger
posted on 18/10/06 at 01:31 PM Reply With Quote
with mild steel wool it is probably oxidizing very quickly.
BTW there is a place at the back of Morrisons in Ipswich that sells all sorts fasteners and tools that I would have tried (Suffolk Fasteners IIRC) they sell in any quantity you need and are very reasonable
