andyd
| posted on 24/10/06 at 04:11 PM |
WANTED: Cortina uprights
Guys,
Anyone got some (or even one) complete upright and hub they don't want?
I'm going to be machining up my own upright/stub axle/hub and steering arm for use with Wilwood brakes so I just want to take some accurate
measurements so I can model the various bits.
There are a few on eBay at the moment and whereas I don't mind rust etc. £90 for some right out of the scrap yard seems a bit steep. Especially
as I won't end up using them. I could sell them on once I've finished measuring but the hassle involved is putting me off.
I know, I know... I'm a lazy.....
goodguydrew
| posted on 24/10/06 at 04:33 PM |
I'd buy them once you are finished with them! I'm also looking for a set!
Wadders
| posted on 24/10/06 at 07:09 PM |
Might be worth thinking of revising the geometry if your going to the trouble of making your own uprights, tina ones arn't perfect i.e lack of
self centering. Not sure what the perfect angles/dimensions are, but someone on here prolly will.
Al
Originally posted by andyd
Guys,
andyd
| posted on 24/10/06 at 07:32 PM |
Absolutely... I'm going to use the standard bearings therefore I want to measure the stub axle and hub dimensions. The hub will be standard PCD
on the wheel size but custom for the Wilwood discs I've picked.
So really I'm only after a stub axle and hub but I figured it's easier to get the whole upright.
andyd
| posted on 24/10/06 at 07:40 PM |
On eBay at the moment there are...
these,these and
these but apart from the ones from the Westie, they seem expensive. It may be the going rate however as they are getting
difficult to obtain.
That last guy says he "usually" has about 5 pairs so if no other options appear then I may cough for one of his rough pairs and tart them
up to try to flog them on later.
Mark Allanson
| posted on 24/10/06 at 07:50 PM |
You can get a whole cortina for £16 on ebay at the moment, 1300 xfloo, uprights, axle, prop, all you would need is 8 lengths of 25mmx25mm erw and your
£250 budget would be a distinct posibility
Mark Allanson
| posted on 24/10/06 at 07:51 PM |
Forgot this
http://www.locostbuilders.co.uk/viewthread.php?tid=53782
flak monkey
| posted on 24/10/06 at 08:53 PM |
How accurate do you need?
Sera
http://www.motosera.com
andyd
| posted on 25/10/06 at 08:09 AM |
I've already got that particular drawing and yes on the face of it that would give me the dims of the stub axle... however, there are bound to
be tolerence issues as I'd have to draw it up in mm (modern CNC eh?! tut! ). Plus the measurement on the bottom left drawing of
0.87"... where exactly is that pointing to? Also what radius curve is there on the transition near the back plate where the rear bearing sits?
Also that doesn't show me hub details.... well, you get my point. Tis a start but I don't like to trust 3rd party measurements when the
result will be propelling me at over 100mph (on a track ocifer!).
But thanks for trying!
Mal
| posted on 25/10/06 at 10:12 AM |
Cortina Uprights
Andy,
You have a U2U with an offer of a pair of uprights,
Mal
andyd
| posted on 25/10/06 at 10:34 AM |
Mal... you have U2U2!
