locoboy
| posted on 14/11/06 at 10:21 AM |
R1 headlight relay
Looking for an R1 healdight relay assembly for a 4XV 1998 engine.
Locoboy
Kissy
| posted on 14/11/06 at 12:19 PM |
Any 12V 30A+ realay should do that job.
chockymonster
| posted on 14/11/06 at 02:25 PM |
I have the headlight side of the loom from a 5pw if that helps? all of the clock bits have been chopped out.
If it's to connect to your 4xv loom then just chop the plug off and solder the wires to the main loom.
locoboy
| posted on 14/11/06 at 06:45 PM |
reason i wanted the R1 in partucular was that i have the r1 loom and it would have been simpler for an electrical numpty to just plug and play rather
then grafting in something non R1!
Locoboy
Deckman001
| posted on 14/11/06 at 09:13 PM |
Contact Desyboy about this he has the moddied loom drawing that was done for his R1 instal into an Indy using the Sierra collumn and stalks, the
indicators were easy, the headlights were a right pain and took quite a while I believe, but this is only if you want to use the original switching on
the Sierra collumn
Hope this helps
Jason
ps, the bike relay wasn't used on Des's car, he had to use a 30A jobbie
