nitram38
posted on 16/11/06 at 03:25 PM |
Wanted 5-core coiled lead steering release
I have tried all the usual suspects, maplins and RS.
They do a 4 core or 15 core keyboard cable. I could use the 15 core and connect 3 cores together, but I would prefer the correct lead.
I am after a 5 core coiled lead for my quick release steering wheel. I have mounted the V2 veypor to it.
I would love the spa 8 pin release but at over £255 it is a bit OTT
balidey
posted on 16/11/06 at 03:30 PM |
I have used these people before, based in Peterborough. They may have some off the shelf, or could make some for you.
http://www.electric-cable.com/
Or, tail-lifts on trailers often use 7 core, so you could try your local Truck spares place.
Or, Durite, they stock most stuff like that.
nitram38
posted on 16/11/06 at 03:31 PM |
Cheers....will checkout
balidey
posted on 16/11/06 at 03:50 PM |
I may have a spare bit, let me get back to you later this afternoon before you buy any.
Edit: Yep, got some, its 7 core, bright yellow , how long do you want it (yeah, i know its coily, but a rough natural / stretched length so i can
send you enough). PM or U2U me your address and i'll try and get it off to you by the weekend.
[Edited on 16/11/06 by balidey]
Sorry, edit that again, i have loads of 4 core, need to double check if we DO have any 7 core. Back to you in a bit
balidey
posted on 16/11/06 at 04:36 PM |
OK, got some 7 core, in black. Only problem is its quite chunky, coil OD is about 50mm, the actual cable od is 11mm. If you want it, let me know.
shortie
posted on 16/11/06 at 04:57 PM |
Funnily enough I am looking for exactly the same, pref 7 or 8 core, could use trailer wire but a bit chunky really.
nitram38
posted on 17/11/06 at 06:07 AM |
balidey, thank you for the offer, but I was hoping for something a bit smaller.
Cheers Martin
flak monkey
posted on 17/11/06 at 09:42 AM |
Spa design do a quick release wheel boss with a connector built into it, have a look here:
http://www.spa-uk.co.uk/design/steeringquickrelease.asp
Edit, ooops just read you first post properly We use them on our race car, they are very good...)
[Edited on 17/11/06 by flak monkey]
Sera
http://www.motosera.com
nitram38
posted on 17/11/06 at 11:24 AM |
Where is the cheapest place to buy them?
£255 from spa!!!!!!
nitram38
posted on 17/11/06 at 01:51 PM |
Found a 5 core Clicky
