dozracing
posted on 21/11/06 at 02:30 PM |
Exeter Show
Hi all,
Thanks to everyone who came and said hello at Exeter, and thanks for all the compliments about the car. Pics attached for those who didn't get to
go.
D.
dozracing
posted on 21/11/06 at 02:32 PM |
New seat swabs for our popular GRP seats.
mookaloid
Nice looking car
dozracing
posted on 21/11/06 at 02:33 PM |
D.
nitram38
posted on 21/11/06 at 02:34 PM |
Nice car!
Where did you get the scuttle wind deflectors and are they carbon?
dozracing
posted on 21/11/06 at 02:36 PM |
Figured out at the show that our Deluxe Starter Kit (item for item) is cheaper than:
Robin Hood,
Tiger Avon,
MK Indy
dozracing
posted on 21/11/06 at 02:37 PM |
Every item on the car is available from GTS Tuning, www.gtstuning.co.uk
Not carbon but carbon effect ABS.
D.
Gav
posted on 21/11/06 at 02:45 PM |
Gotta admit that is one hell of a good looking car you got there Darren
How much are you retailing the seat pads for?
James
posted on 21/11/06 at 04:00 PM |
I had a couple of looks at the show... was very impressed.
James
- Muhammad Ali
dozracing
posted on 21/11/06 at 04:30 PM |
Just pricing the seat pads at the moment, cost is totally dependent on the material that covers them. I'm going to have to produce an options
list for this.
The GRP pads themselves for self covering would be £35.
Kind regards,
Darren
Andy North
posted on 21/11/06 at 05:25 PM |
Went last year and enjoyed it. This year I am stuck here in Africa
scotmac
posted on 22/11/06 at 07:35 AM |
Robin Hood,
Tiger Avon,
MK Indy
LOL...good one. Robin Hood is definitely not quality (btw, nice car), but return for dollar is where they live. OK, let's do a comparison, based
on what is *published* on the GreatBritishSportscars and GTS Tuning web-sites. The RobinHood 2b has the following parts not found in the GTS Panther
Steering and Suspension Components
* Pair of front coil over dampers
* Pair of rear coil over dampers
* Pair of track rod ends and lock nuts
* One double universal jointed steering shaft ???
* Steering column support bracket
* Steering column bush bracket
Set of Stainless Steel Inner Panels
* Firewall panels
* Feet panels
* Dashboard panel
* 'P' clips
Exhaust Components
* Stainless steel exhaust silencer
* Stainless steel 4 into 1 performance exhaust
* Silencer baffle
* Stainless steel exhaust heat protector
* Two rubber exhaust mounts
Windscreen Components
* Toughened glass windscreen (BS Kite marked)
* Two piece, rounded aluminium frame
* Lower windscreen to body 'T' seal
* Glazing rubber
* Windscreen pillars (pair)
* Wiper blades
Light Set
* Chrome headlamp units (pair)
* Sealed beam units (pair)
* Front flasher lamps (pair)
* Pair of SVA extensions
* Number plate lampRear combination lamps (pair)
* Rear fog lamp
* Side repeater lamps (pair)
* Reversing lamp
Interior Components
* Mountney 11" leather rim steering wheel
* Mountney steering boss and horn push
* Perspex for instruments
* High quality sable or black cockpit carpet
* Length of vinyl
* Cockpit edge finishing material
* Snap on edge trim
* Litre of high-grade glue
Miscellaneous
* Two Sabelt four point harnesses
* Set of five, five spoke alloy wheels and nuts
* Set of five, 205/650 15 Yokohama A539 tyres and valves Number plate lamp bracket
* Washer bottle and pump
* Handbrake cable for drum brakes
* Fuel tank
* Maxcool Radiator
* Two hoses and two bends
* Electric radiator fan
* Radiator locating bracket material
* Twin universally jointed propshaft with grease nipples
* Servo mounting panel
* Set of three metal brake pipes
* Four flexible brake pipes
* Locking aero style fuel cap and neck
* Demister vents
* Improved front cycle wing brackets
* Multi-bend tube for cycle wing brackets
* Stainless steel stone guards and beading
* Set of bonnet catches
* Bonnet catch safety rail
* Bonnet edge trim
* Nose cone grille
* Nose cone badge
* Rear wing piping
* Handbrake angle
* Spare wheel threaded rod
* Tube of high grade, polyurethane sealer
* General fastener pack
* Offcut pack
* Pair of gloves
* Instruction video (12 hours)
If you made this far down in this post, here are the part (s?) that the GTS has the RH does not:
Sierra Front Uprights
Ooops, those are exchange, so not really *included* in the Panther.
scotmac
posted on 22/11/06 at 07:46 AM |
Note, to be fair, the Panther is only 2000gbp's vs the 3000gbp's for the 2b. However, on top of that 2000, GTS charges 180 for shocks and
springs, 700 for an exhaust system, 120 for a propshaft, 230 for a lightset, ....
[Edited on 22/11/06 by scotmac]
flak monkey
posted on 22/11/06 at 08:28 AM |
Some of those parts are not included in the kit, because they dont form part of what the Panther is, there has never been a windscreen available for
the Panther, though Darren is in the process of developing one at the moment I believe.
Also:
These arent required because there is a tube welded into the top of the bulkhead to support the lower end of the column.
Like you say the RH kit is £1000 more anyway.
To be honest I dont think, price wise, theres much to choose between RH and GTS if you do your sums, but I know which one will give you better quality
for your money
You pays your money...
Sera
http://www.motosera.com
hellberg
posted on 22/11/06 at 09:29 AM |
some crappy Exeter pics
Hi!
My first post here.
I went all the way from Sweden to Exeter and here are some photos from the show (152 pics in total, follow the link):
Please move/delete it if it´s offtopic.
All of my crappy pictures HERE
[Edited on 22/11/06 by hellberg]
DAN57
posted on 22/11/06 at 08:23 PM |
Wow that is one lovely car and stunning colour. I love it and want one. I was dissapointed to not have been able to go this year but now I am gutted.
I'd loved to have had a good look round that. Does any one know what colour it is called? I may have found the answer to my what colour body
question. Top work Darren and loving the seat pads too. Quality.
tom_loughlin
posted on 6/12/06 at 08:12 PM |
Beautiful lokoing car Daz, Think its got to be the only car that looks really good in silver!
Keep up the good work mate!
Tom
