flak monkey
| posted on 28/11/06 at 09:48 PM |
Inlet manifold gasket/plate drawings
Has anyone got drawings, or know of where to find them, for inlet manifold gaskets/plates for enegins commonly used in locosts? (e.g. pinto,
crossflow, xe etc)
Sera
http://www.motosera.com
liam.mccaffrey
| posted on 28/11/06 at 09:53 PM |
i have ecotec
Build Blog
Build Photo Album
| posted on 28/11/06 at 10:15 PM |
Think the Payens catalogue may show gaskets but not sure of scale
JohnN
| posted on 28/11/06 at 11:18 PM |
I've just drawn up a blacktop Zetec Inlet in AutoCAD, based on measurements taken from the plastic inlet manifold. Printed it out on paper and
it fits the plastic manifold as well as I could have hoped (not checked against the engine, will do that this weekend). It will be a few weeks before
I have the flange machined out of Aluminium, so the final fit has yet to be tested.
pathfinder
| posted on 28/11/06 at 11:20 PM |
Inlet manifold gaskets only cost a couple of quid from the local motor factors. Making manifolds is a nice idea but I was put off using gaskets as the
template as they are often in accurate. I also found that there were far too many variations in carbs that people wanted to stick on the manifold. All
the best with it though!!!
bob
| posted on 29/11/06 at 11:32 AM |
I could send you an old inlet manifold i have kicking around for a series 1 silvertop from my 1800,its of no use to me so you might as well copy
it.
As mentioned some aftermarket gaskets are very inacurate infact OE can sometimes be as bad.
