zxrlocost
| posted on 11/12/06 at 08:28 PM |
cortina "book" wishbones wanted
and again as above anyone got some book wishbones for cortina uprights
ta chris
mike-ktm
| posted on 11/12/06 at 09:56 PM |
Have a set of MK wishbones, done in primer then metallic black + lacquer
fully poly bushed and never used since prepared.
u2u an offer if you're interested (also have new ball joint set if needed)
Mike
mistergrumpy
| posted on 11/12/06 at 10:02 PM |
I have GTS ones. Sprayed lightly in primer then matt black. Will easily come off. Never used, just realised I've got wrong ones (see todays
post) U2U an offer if interested.
procomp
| posted on 12/12/06 at 01:49 PM |
Hi play it safe and use the ones from the chassis suplier as they actually come with some castor on as standard as most already have found that others
have verry little or none at all.
cheers matt
