paulf
posted on 20/12/06 at 11:08 AM |
Type 9 bellhousing.
I am after a type 9 bell housing , has anyone got one that is in the way in the morthants area ? or not to far away .
Paul.
DavidM
posted on 20/12/06 at 01:05 PM |
Hi Paul,
Do you need one for keeps or just to borrow, for measuring or something. I've got one you can borrow, but I'll need it back as I'm
fitting a 5 speed over the winter.
Let me know,
paulf
posted on 20/12/06 at 02:05 PM |
Its for my zetec conversion that I am still trying to make fit.Im intending to try and remove as much of the sticking out parts behind the starter
motor and clutch release lever as possible to gain some clearance in the transmission tunnel so I can fit it further back.
So ideally i need one to hack about but it may help to just be able to measure and offer it up to the engine to get some idea of how much space i can
save.
Paul.
MikeR
posted on 20/12/06 at 05:30 PM |
i've got one you can have - although i suspect i'm not that local.
Perhaps we could organise a courier service, i take it someones, they move it on etc etc.
paulf
posted on 20/12/06 at 08:37 PM |
Thanks Mike ,
If i get stuck for one locally i could have a run up to collect it , im off work between christmas and new year, and will be hoping to get out in the
seven for a good run before taking it off the road at the end of the month, if the weather is ok I could come in it for a trip out.
Paul.
posted on 20/12/06 at 08:53 PM |
Got one you can have , I'm in the Cambridge area . Could drop it off in Bar Hill if thats any good to you
