locoboy
| posted on 9/1/07 at 09:59 PM |
sealed beam inc sidelights
Hi im after a set of sealed beam units with side lights.
Anyone got a spare set for sale? or know where i can get a locost set!?
I have the casings i just need the sealed units themselves.
[Edited on 9/1/07 by locoboy]
Locoboy
snippy
| posted on 9/1/07 at 11:45 PM |
I recently upgraded from sealed beams to some halogens as one of my sealed beams had blown. However i`m pretty sure I still have the other sealed unit
boxed up and it was in full working order if 1 is any good to you?
Nick
DavidM
| posted on 10/1/07 at 01:17 AM |
If they're still going Lolocost are very reasonable for sealed beams. Generally you need a plug in side light loom for the side light and it
shines through a small window in the back of the sealed beam. Unfortunately the looms are often about £9 each from those stalls at kit car shows.
Bluemoon
| posted on 10/1/07 at 08:47 AM |
Might be an idea to try your local motor factor, you might be suprized..
Dan
| posted on 10/1/07 at 09:36 AM |
quote: Originally posted by DavidM
. Generally you need a plug in side light loom for the side light and it shines through a small window in the back of the sealed beam.
don't recall ever seeing one with a side lamp in there .... so as above ^^^^
I've got a pair you can have for free, regular 7 inch(?) ones from a Land Rover - same size as MGB, mini and a plethora of other British cars
from the 60-80s.
| posted on 10/1/07 at 10:53 AM |
All the old Minis had them. 7" are still freely available and you can get H4 conversions for them from
VWP or similar which are a massive improvement. There's a
7" sealed beam on there with glass pilot window for £7.69.
locoboy
| posted on 10/1/07 at 11:35 AM |
Cheers for the suggestions, good info as usual.
Got a a pair on order now.
Thanks again
Locoboy
