Author: Subject: Mild steel bright bar, 110mm to 125mm dia, 250mm long or two 125mm bits
NS Dev
posted on 22/1/07 at 01:31 PM Reply With Quote
as the title, anybody in the leics area got any bits if bright bar that size?
cheers
Nat
[Edited on 22/1/07 by NS Dev]
posted on 22/1/07 at 01:48 PM Reply With Quote
that's a big chink Nat - are you planning to machine your own sprockets?
nige
posted on 22/1/07 at 02:40 PM Reply With Quote
bright bar
we roll the stuff here
but ive just looked on stock and the
nearest we keep is 130 mm square
below that is 115mm but all our bright bar
is square section
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
NS Dev
posted on 22/1/07 at 05:38 PM Reply With Quote
Needs to be round I'm afraid, only have a 3 jaw chuck!!!
I'm turning bosses to mount 108mm cosworth CV joints to a 50mm hollow driveshaft, and mount sprockets to the back of the same bosses.
posted on 22/1/07 at 06:57 PM Reply With Quote
Have you got a hydraulic ram repairers near you ? not mild steel but may have the size you need from an old ram if youll excuse the expresion.
NS Dev
posted on 23/1/07 at 08:50 AM Reply With Quote
hmmmm, interesting idea, will ave a look, there are a lot of ram repairers here as we are surrounded by quarries!
really just needs to be weldable steel so ram tube/piston rod will do the trick
nige
posted on 23/1/07 at 01:57 PM Reply With Quote
round bar
found some
u2u me if your still in the market for some
