Author: Subject: wanted : Coilovers
novacaine
posted on 23/1/07 at 05:28 PM Reply With Quote
wanted : Coilovers
as the title implies,
im after a set of coilovers for my up-and-coming project, my main requirement is that they are very cheap, i realy only need something that will get my car on the road so seeing as i am going the "locost" way i guess i shouldnt realy be spending mega money on shocks and springs
anyone want to get rid of their dreaded zeemarides?
cheers
Matt
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
Kissy
posted on 23/1/07 at 05:36 PM Reply With Quote
When you say 'on the road' do you mean through SVA? If it's just to make the car manoueverable just make 4 tie rods.
novacaine
posted on 23/1/07 at 05:40 PM Reply With Quote
duh, i never actualy thought of that, but just out of interest what would the going rate be for some second hand entry level coilovers?
if you've got some for sale just u2u me and if the offer is good enough i might just buy them for use later
cheers
Matt
[Edited on 23/1/07 by novacaine]
dyntan
posted on 31/1/07 at 08:49 PM Reply With Quote
hi
not exactly sure what you mean, can you explain or add a photo i'm in the same predicament requiring coilovers
ta
gazza285
posted on 1/2/07 at 06:45 AM Reply With Quote
I used bits of plywood strip, cut to the length of a coilover and drilled a hole in each end, when they are bolted on they keep the car at approx ride height and allow the car to be manouevered. If you look in my photo archive there's a huge photo (look in the rear brakes file, it's the first photo) in which you can see one of them in action.
Pezza
posted on 1/2/07 at 10:37 AM Reply With Quote
The chap I bought my part built kit from had made these, though solid mild steel might have been slight overkill
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
posted on 1/2/07 at 11:05 AM Reply With Quote
We had some 2"x1" with Koni written on it specially for the job.
