Author: Subject: rivnut tool
myeates
posted on 29/1/07 at 08:15 PM Reply With Quote
rivnut tool
hi guys
anybody got a spare or unused rivnut tool i dont want to make own and dont really want to buy new if i dont have to. did have one not so long ago but seem to have lost or misplaced rather well was mainly used for M5/M6 rivnuts
graememk
posted on 29/1/07 at 08:23 PM Reply With Quote
if you only have a few to do i can lone you one for a few weeks seeing as your only just up the road
myeates
posted on 29/1/07 at 08:37 PM Reply With Quote
that would be good thank you probably got about 15 to do trouble is it would be between now and 6 months as things are going in as and when they need to till the end of the build hopefully not long
would probably need it longer than you would be prepared to loan thanks
[Edited on 29/1/07 by myeates]
graememk
posted on 29/1/07 at 08:43 PM Reply With Quote
herrm i know whats going to happen here, i'll need it as soon as you have it, if you could cut it done to say a month its yours, if not your going to have to buy one
myeates
posted on 29/1/07 at 08:56 PM Reply With Quote
yep that the usual thing that happens. thanks for the offer mate appreciate it but dont want to put you out incase you need it will try find a good cheap one thanks again mate
mad4x4
posted on 30/1/07 at 11:10 AM Reply With Quote
MK used to do a machined one, you got it when you bought part of the indy KIt maybe they will still sell em seperatly..
Scot's do it better in Kilts.
macnab
posted on 30/1/07 at 02:15 PM Reply With Quote
yeah MK supplied me with one, broke on the first attempt
posted on 30/1/07 at 02:23 PM Reply With Quote
How many rivnuts are you planning to set? If there aren't too many, you can use a length of steel strip with a bolt, nut and washer.
Drill a hole in the steel strip, leave enough for a handle. Grease the bolt, then fit the nut & washer. Put the bolt through the hole in the steel strip, then thread on the rivnut fully. Push the rivnut into the hole, and start winding the nut down against the steel strip. You might need another spanner to stop the bolt turning (3 hands are useful!).
This will set the rivnut properly, but will rapidly knacker the nut & bolt - if you manage to set 6 or 7 before they give out you'll be doing well.
If you have a lathe you can make a fancy one, as described on my website (link below). That one is much easier to use, and lasts for years!
myeates
posted on 30/1/07 at 07:50 PM Reply With Quote
thanks david may try that oneat the weekend will still try and find my other one thanks all
myeates
posted on 4/2/07 at 06:46 PM Reply With Quote
found it the stupid thing had slid down behind one of the shelves and rested on the support so i couldnt see it i thought id looked everywhere hehe god job i didnt buy another one that would of been very anoying
