TimC
| posted on 23/2/07 at 12:11 PM |
No Longer Wanted: Blind Black Rivets
Looking for Black Blind Rivets - can anyone point me in the right direction?
Prefer 3.2mm but not vital.
Cheers.
TC
[Edited on 23/2/07 by TimC]
Guinness
Got mine from NF Auto.
Got some 5mm left if you want a few.
Mike
Jon Ison
| posted on 23/2/07 at 12:12 PM |
I found some on ebay when I was looking for green ones.
mackei23b
| posted on 23/2/07 at 12:14 PM |
I got mine from Primary Fasteners, very helpful and quick delivery
Tel 0121 247 5191
http://www.prifast.co.uk
Ian
TimC
| posted on 23/2/07 at 12:16 PM |
I just spoke to NF Auto - they said that they were open - i.e had a hole in the middle. Do I need to call them back?
Mike
mackei23b
| posted on 23/2/07 at 12:25 PM |
Speak with Primary Fasteners.
You can't get black anodised closed rivets due to the manufacturing process, that said there is another type which I can't remember,
Morgan Sports Cars use them, so I figured they where good enough for me! At least that was what the guy from Primary Fasteners said.
Ian
TimC
| posted on 23/2/07 at 12:32 PM |
Ian
Cheers Ian
Just had that exact same conversation with Primary Fastners. What a top man he was!! Recommended!
richard thomas
Tim, if you are after captive head (or closed) blind rivets to stop chassis tube moisture ingress, you could use standard open blind rivets but dip
the ends in a sealant before you insert and pull them - this will have much the same effect. This way you can use black ones from NF.
Bluemoon
| posted on 23/2/07 at 01:51 PM |
Yep I am using the captive headed primaryfastner ones, and one of his hand seting tools. Both are really good, unlike the cheapo pop-rivets and guns.
But as said the rivets are not closed, but do retain the head well. I have diped them in PU sealant before setting to ensure they seal..
Dan
