capri_big_jim
| posted on 1/3/07 at 05:26 PM |
Some steel box section
Hey guys im after a short length (6inches) of steel box section, it needs to be 5cmx6cm....
and not to chunky gauge....
Let me know if u have any....
big_wasa
| posted on 1/3/07 at 05:31 PM |
I have a bit of 50mmx50mm 3mm wall you can have.
Dont think you will get 50mmx60mm ?
capri_big_jim
| posted on 1/3/07 at 05:42 PM |
the only reason i stipulated 50mm x 60mm was cause thats the hole in the flage i have...
do u think if i can cut it down the middle i can widen it....??
thanks
Jim
big_wasa
| posted on 1/3/07 at 05:55 PM |
Depends on what tools you have.
Whats it for ?
capri_big_jim
| posted on 1/3/07 at 05:58 PM |
Its for a flange to bolt on to a plenum chamber, the hole in the flange is rectangle and i need to come out of that and merge in to some steel tube so
i can connect up to some silicone hose.....
i have the tube but i need some box to be able to go from the flange and merge in to the tube...
i have cutting and welding equipment so i should be ok....
thanks
Jim
big_wasa
| posted on 1/3/07 at 06:02 PM |
Yours if you want it mate but 3mm wall is a bit solid for a manifold.
capri_big_jim
| posted on 1/3/07 at 06:06 PM |
ok mate i think ill leave it until someone comes along with something a bit thinner then...
thanks
Jim
Chippy
| posted on 1/3/07 at 06:10 PM |
Why don't you just cut and taper the tube to a square 5cm x 6cm to fit, shouldn't be too hard. HTH Ray
big_wasa
| posted on 1/3/07 at 06:18 PM |
I have a piece of 16swg steel sheet big enough to fold and make your own.
capri_big_jim
| posted on 1/3/07 at 07:00 PM |
Yhe iv just been sat looking at the problem, and have decided that if i cut the end of the tube about 6 times i can fold these out, tack them in to
the square hole then use some steel sheet to infil the gaps....
how does this sound?
thanks
Jim
Chippy
| posted on 1/3/07 at 11:05 PM |
Another thought, if you made a wooden block 50 x 60 tapered it and drove it into the pipe, you could dress the pipe round it, gradualy pushing the
timber in until you had the required shape your after. Ray
capri_big_jim
| posted on 1/3/07 at 11:12 PM |
sounds like a good idea in theory, but would it work?
wouldnt i have to heat the metal up lots and lots...
thanks
Jim
Chippy
| posted on 1/3/07 at 11:38 PM |
Wouldn't have thought so, if you could get a suitable piece of hard wood, bit of oak maybe, you should be able to dress the tube onto it a bit
at a time. Thinking about it thats how I modified the tubes that my air filters are mounted on, the hole in the air flow meter is square. Ray
[Edited on 1-3-07 by Chippy]
capri_big_jim
| posted on 1/3/07 at 11:45 PM |
Thanks mate, i will give it a go tomorrow....
thanks for all the input..
Jim
