the_fbi
posted on 6/3/07 at 10:51 PM |
M22 x 1.5 stainless cap
As subject.
I need an M22 x 1.5 blanking cap to go on an EGR connection on my manifold.
Mild steel I guess would be OK, stainless preferred.
I've searched and can't find anywhere
It needs to be a female to go onto a pipe. Some V8's have then as core plugs but not caps
Sources appreciated, can anybody make one up perhaps?
ta
Chris
posted on 7/3/07 at 07:55 AM |
what do you mean by cap? cap head or a plug of some description?
the_fbi
posted on 7/3/07 at 08:18 AM |
Like the picture below, but with a M22 x 1.5 thread on the inside, some nice hex flats on the outside, and in stainless.
So nothing like the picture below, but to go on the outside end of a pipe.
posted on 7/3/07 at 08:55 AM |
Can you not use a short length of rubber hose, jubilee clip it over the male threaded EGR outlet. Then plug then other end with a cut down M22 set
screw secured with another jubilee clip
Not the most elegant of solutions I know, but practical and cheap with readily available parts.
the_fbi
posted on 7/3/07 at 12:52 PM |
This pipe is about 70mm from the exhaust port and about 50mm from the head. It'll be getting a tad warm!
I should just get it welded up but I hoped a cap would be easy to find.
