jimbona2
| posted on 17/3/07 at 04:13 PM |
things i need (engine bay area)
could do with the following, let me know prices if any of you have any of these. cheers
inlet manifold
oil filter
exhaust manifold
radiator (with fan?)
handbrake assembly
set of wheels (14 inch)
i have a 2 litre, silver top zetec engine Avon.
[Edited on 18/3/07 by jimbona2]
TangoMan
| posted on 17/3/07 at 05:10 PM |
Oil filter is available from any auto store.
The same as CVH Escorts and most other Ford engines.
I have a push through Electric fan (as I need pull through!! due to inboard suspension).
I have a standard exhaust manifold and the first part of the downpipe to match. It even has the oxygen sensor still in it.
What are you doing about inlet, as MNR supply mounting flanges and tube is cheap as chips f you plan to use throttle bodies and make your own
manifold.
Summer's here!!!!
