Author: Subject: Wiring help.
scutter
posted on 19/3/07 at 03:14 PM Reply With Quote
Wiring help.
Ok, Before I get miffed and torch the car, Is there anyone in the West Oxford area that is will to pop over and help with the wiring of the megajolt?
I'm on the second attempt of wiring as the first go the unit would only fire in limp home mode no matter what was connected.
There is a good danger of pushing it into the shed for this year if not ready for the shows this year as I'm runnning out of time for everything.
ATB Dan.
[Edited on 19/3/07 by scutter]
rayward
posted on 19/3/07 at 03:15 PM Reply With Quote
too far away to po around and help, but then reasons for it running in limo home mode are,
no signal from VR sensor (faulty or too far away from trigger wheel)
wiring to VR sensor reversed
Faulty EDIS unit
hth
Ray
scutter
posted on 19/3/07 at 05:24 PM Reply With Quote
Right that's the first of many mistakes I've made, I presumed that the edis needed to see a signal for it to fire even in limphome mode.
Bad night/day yesterday/today, time for a pint and then to start again.
Still after a hand/ conifidence checker tho.
ATB Dan.
paulf
posted on 19/3/07 at 06:35 PM Reply With Quote
u2u sent
Paul.
