Duncan Mould
| posted on 22/3/07 at 09:38 PM |
Grasshopper plans / 1/4 size 7
Does anyone out there have a set of plans for a grasshopper or small childs lotus 7 replica.
Many thanks
Duncan
jonno
| posted on 22/3/07 at 10:04 PM |
Yes i've got a set, what do you want to know ?
Duncan Mould
| posted on 22/3/07 at 10:34 PM |
Is it worth me buying them at £35 or could I suss most of it out myself? ( having built 5 real size 7's)
Just how comprehensive are they and how detailed are the plans. I would hate to purchase a couple of poorly photocopied pages stuck together.
graememk
| posted on 23/3/07 at 08:52 AM |
if you've built a robin hood i hink you could manage a childs 7
D Beddows
| posted on 23/3/07 at 09:28 AM |
To be honest you could easily figure it out yourself - I suspect it will be the same script as for a full size Locust or Hornet ie what you'd
get for your money would be a set of full size paper templates for the mdf tub and a bit of a build manual which is all mostly common sense to be
honest
wilkingj
| posted on 23/3/07 at 01:17 PM |
Cant see the problem... Take Mc Sorley Plans and divide everything by 4.
Shouldnt be too hard. Especially if you have already built 5 Se7ens already.
Best Regards
Geoff
http://www.v8viento.co.uk
jonno
| posted on 23/3/07 at 06:05 PM |
D Beddows is just about spot on, the main bit is the full size plans to cut the ply or mdf the rest is common sense really.
If you've build a full size one, this should'nt be a problem.
I only got them as they came with a unfinished project with the grp
Duncan Mould
| posted on 25/3/07 at 08:15 PM |
I have worked out some general dimensions and plan to start fabricating the chassis soon!
