TimC
| posted on 6/4/07 at 11:03 AM |
M12 Union Type Widget
I'm trying to find some kind of union with a M12 male fitting one end and a tube to accept a hose (size not important) at the other.
It's an overflow outlet so almost any material would do the job.
Any ideas?
Ta
907
| posted on 6/4/07 at 12:41 PM |
Bore an 8mm (ish) hole through a bolt, then cut off the head?
Paul G
fesycresy
Acorn Fluid Power in Cwmbran.
You could probably use a compressed air fitting.
