supercat
| posted on 10/4/07 at 12:47 PM |
Wanted: Sierra Column Indicator Cancel Bush
As above - looking for the bush that cancels the indicators on a Sierra Steering Column.
Cheers.
| posted on 10/4/07 at 12:52 PM |
If you can't find one you can drill a shallow hole in the column and weld a suitably fettled bit of metal in place. Works just as well....
RazMan
| posted on 10/4/07 at 01:08 PM |
A Momo boss (and others afaik) has this built in.
Raz
big_wasa
| posted on 10/4/07 at 01:10 PM |
Have a slightly damaged one you can have. The tag that sits in the boss is broken of.
supercat
| posted on 10/4/07 at 01:16 PM |
I've got the Mountney boss and it doesn't have it... so the main problem is the column is loose in the mount, need the bush to make up the
length.
supercat
| posted on 10/4/07 at 01:17 PM |
U2U sent!
TimC
| posted on 10/4/07 at 02:03 PM |
I may have one in working order. Send me a U2U to remind me to let you know tomorrow. If I have, I'll chuck it in the post.
Memory like a sieve!
big_wasa
| posted on 10/4/07 at 04:29 PM |
u2 Back....
