| posted on 14/4/07 at 09:02 AM |
Water Rail
Anyone got a one of those Raceline water rails for a Zetec lying around they want to pass on?
Big Stu
| posted on 14/4/07 at 09:38 AM |
Yeah got loads of them lying about... I wish at over a hundred quid a pop. I could not justify buying one so I made my own using the existing
thermostat and a length of stainless tubing back to the top of the radiator.
| posted on 14/4/07 at 10:03 AM |
Can you put some pictures up and how much?
deneo
| posted on 14/4/07 at 10:13 AM |
water
will make you 1 thanks dene
chris_harris_
| posted on 14/4/07 at 10:21 AM |
And i can vouch for dene's work too. its great. Have a look in my archive.
Regards Chris
stevebubs
| posted on 14/4/07 at 04:27 PM |
A water rail is only needed if the engine is butted up so close the the scuttle you can't get the standard thermostat housing on there.
  Zetec Water Pipes
TangoMan
| posted on 14/4/07 at 08:22 PM |
I didn't need a water rail. The original thermostat housing fitted without a problem so i just sourced some stainless tube and silicon hose to
assist with plumbing to the radiator.
Summer's here!!!!
bob
| posted on 15/4/07 at 09:03 AM |
Just finishing off my plumbing, more pics in my archive under zetec water folder.
[Edited on 15/4/07 by bob]
Schrodinger
| posted on 16/4/07 at 08:03 AM |
Tiger uses the original thermostat housing and a length of ally tube as above.
