Author: Subject: ecotec cam pulleys
liam.mccaffrey
posted on 17/4/07 at 11:04 AM Reply With Quote
ecotec cam pulleys
wanted
ecotec cam pulleys
or might they be the same as an XE?
Build Blog
Build Photo Album
ned
posted on 17/4/07 at 11:21 AM Reply With Quote
same profile as very late xe's, square teeth rather than round iirc. oh and slightly smaller as the valve angle is different and the head is narrower so they're closer together.
[Edited on 17/4/07 by ned]
beware, I've got yellow skin
liam.mccaffrey
posted on 17/4/07 at 12:05 PM Reply With Quote
so they're different?
Thanks ned
Build Blog
Build Photo Album
ned
posted on 17/4/07 at 04:23 PM Reply With Quote
late xe's (after a certain engine no) used the same pulleys as the later ecotec. There might be some info on sbd's site, I'll have a look. Why not just get some verniers
Ned.
not sure if it was the same time they went to the plastic auto tensioner or not. LN meant 'low noise' and was an attempt to meet newer regs before they had to change the valve inclination angles to get through the more stringent emissions regs as the xe put through too much on cam overlap and over run iirc.
http://www.sbdev.co.uk/Info_sheets/2.0L%20Cambelt%20&%20pulley%20arrangements.htm
pps here you go:
http://www.sbdev.co.uk/Vernier%20Pulleys/Vernier_Pulleys.htm
so if it's an xe newer than 93 and has the squarer style pullleys it 'should' fit
liam.mccaffrey
posted on 18/4/07 at 03:11 PM Reply With Quote
shameless bump
Build Blog
Build Photo Album
