MattCraneCustoms
| posted on 4/5/07 at 08:06 PM |
HELP QUICK FOR STONELEIGH MK LOCK NUT BALL JOINT THING
Hi there,
I'm posting on behalf of Gaz from Croft, leicestershire, a member of the forum who hasn't been able to get on the forum for some reason.
He's after a lock nut, for the MK top ball joint, M18 x 1.5, and he wonders if anyone local can help him out?? Otherwise he's stuffed for
stoneleigh!! If anyone can help, he's available on 07967 048611.
Matt
graememk
| posted on 4/5/07 at 08:26 PM |
mine went in the kit i had to get some from mk last year at the show baz put some on teh van for me
ReMan
| posted on 4/5/07 at 09:50 PM |
Just been and looked, sorry thought I had one as I swapped my MK upper wishbones for a GTS (yes GTS) ones, but hav'nt.
Best bet is try Go Fixings in Hinckley, not bad stock of odd sizes, else got to a decent Motor factors, again locally I know RAE MOTOR FACTORS 01455
637313 and get them to see if you can get a joint, with new nuts included.
Col
cjtheman
| posted on 5/5/07 at 05:27 AM |
a bit late to stick it in the post but i have home made ones down here in south wales you can have if you want to collect
cheers
colin
| posted on 5/5/07 at 08:51 AM |
Probably just me but
Personally I would put some threadlock on it and drive to the show, someone there will sell them. Conduit gland nuts are the right size if you have
any electrical contractors nearby.
snippy
| posted on 5/5/07 at 09:15 AM |
have you tried ringing around local motor factors to get hold of a complete ball joint? Parkers at Syston are open until 11pm even on Sundays and the
motorist Centre at Earl Shilton will always order stuff in, same day usually, they`re also open Sundays. You just need to know what car the ball joint
is off?
Nick
