Author: Subject: Cap head bolts Wanted
nitram38
posted on 6/6/07 at 03:01 PM Reply With Quote
160mm long and M10 1.25 pitch!
An alternative would be a longer M10 bolt that can have the shank re-threaded to 1.25 pitch.
It is for my R1 engine.
I would rather the correct bolt size than re-threading the engine block.
Cheers Martin
welderman
posted on 6/6/07 at 03:08 PM Reply With Quote
how many
material. ie stainless or mild steel H/T
Thank's, Joe
I don't stalk people
nitram38
posted on 6/6/07 at 03:14 PM Reply With Quote
how many
I only need 2 and I would prefer stainless.
PeterW
posted on 6/6/07 at 03:33 PM Reply With Quote
Martin
Ttry Fast Fix Direct - usually have that sort of thing
Do a google for them
Peter
nitram38
posted on 6/6/07 at 03:41 PM Reply With Quote
Tried them.
I think that I am fcuked!
Max length is 100mm.
It looks like I might have to rethink my fixing points on the chassis.
pewe
posted on 6/6/07 at 04:01 PM Reply With Quote
Try PFS in Arborfield 0118 932 8832 do all sorts of stainless and used to supply Xtrac, failing that AHC Camberley 01276 709069 are helpful. Good luck, Pewe
Aboardman
posted on 6/6/07 at 04:04 PM Reply With Quote
http://www.a2stainless.co.uk/M10-x-1-25-x-115mm-Socket-Capscrew-A2_AEE5.aspx
115mm long is the longest i found
or 160 but as a bolt head
http://www.a2stainless.co.uk/M10-x-1-25-x-160mm-Hex-Bolt-A2-_A92P5.aspx
[Edited on 6/6/07 by Aboardman]
nitram38
posted on 6/6/07 at 04:12 PM Reply With Quote
Pewe, thanks for the numbers. I rang both and they are going to try and locate some and will ring me back in the morning.
I am keeping my fingers crossed !
nitram38
posted on 6/6/07 at 04:15 PM Reply With Quote
Aboardman
just seen your post. I can change to hex head, perfect thanks!
posted on 6/6/07 at 04:55 PM Reply With Quote
I'll try my local fastener although I wasn;t successful last time I offered this service!!
cap head in 160mm long and M10 1.25 pitch, fully threaded or else a set screw (fully threaded) in stainless.
is that ISO thread or some fine/coarse variant?
GazzaP
posted on 6/6/07 at 05:36 PM Reply With Quote
try willenhall fastners they are very good and can get specials mad can't remember there number though!
www.gmpmotorsport.co.uk
iiyama
posted on 6/6/07 at 07:36 PM Reply With Quote
Get some 160 M12's turned down to correct diameter, and then I can lend ya an M10 x 1.25
die.......
If its broke, fix it. If it aint broke, take it apart and find out how it works!
welderman
posted on 6/6/07 at 09:13 PM Reply With Quote
i will know by morning, will let you know
Thank's, Joe
