matt_gsxr
| posted on 9/6/07 at 08:51 PM |
Sierra horn/steering wheel contacts
Hi there,
I swapped my adjustable steering column for a non-adjustable via this group, which was good.
Unfortunately in the swap I lost the electrical bit that allows the horn button on the steering wheel to work (arrowed in diagram). I need this as I
have a steering wheel with buttons on it, which I'd like to use.
I tried the breakers today but they didn't have a single Sierra!!
Has anyone got one of these that they have no use for?
I also lost the bit of sprung steel which holds the indicators on, but I guess I can fashion one of these.
Thanks,
Matt
  horn contacts needed
TGR-ECOSSE
| posted on 9/6/07 at 09:12 PM |
Hi. My local scrappy has a sierra estate in just now. I can have a look tomorrow and let you know. Anybody else looking for anything while i am there?
Cheers Ronnie
matt_gsxr
| posted on 9/6/07 at 09:16 PM |
thanks
omega0684
| posted on 10/6/07 at 09:53 AM |
siera steering column casing
hi there
if you are going to the scrappy, could you grab one small piece for me please, i need the siera column casing and the two brackets that the top screw
by the hazard light button screws into and bottom screw screws into, they are little m shaped brakets, if you could get all screws as well it would be
a big help.!
thanks Al
TGR-ECOSSE
| posted on 10/6/07 at 11:35 AM |
Just been to scappy and got the horn connector thingy. The column casing was smashed but got 1 m shaped bracket thing. omega0684 is your column an
adjustable one or a fixed one? I can ask about for you. u2u sent to both of you.
Cheers Ronnie
