Author: Subject: Wanted: Radiator
Catpuss
posted on 24/6/07 at 09:10 PM Reply With Quote
Wanted: Radiator
Rather than part cash with somewhere else first, I thought I'd check and see if anyone has a spare/left over suitable rad for sale for an MK Indy?
I've got a Polo one I bought from here, but its the wrong type as usual with my luck
gary gsx
posted on 25/6/07 at 10:51 AM Reply With Quote
I have a recon micra one up for grabs
Catpuss
posted on 1/7/07 at 05:12 PM Reply With Quote
I'm now the happy owner of a MK rad thanks to graham.Thanks for the other offers though I'm sure there are quite a few others of us with part builds that are going to need rads.
TangoMan
posted on 1/7/07 at 08:19 PM Reply With Quote
So Rich,
Does this mean you are now into the build.
If so I might drop in when I am next in the area to see how you are getting on.
Summer's here!!!!
Catpuss
posted on 2/7/07 at 07:38 PM Reply With Quote
Getting there.
I just went into the garage tonight to mock up a side pannel. It suddenly looks very different with the nice red side.
At the moment everything on the car is pretty much mocked up not final tightened so I can work out what order to put things together in. I don't know how many times I've had the steering column off
The next job this week is to test the alternator I have and mock up a bracket. I'll probably work out something with card/ply to get the shape then wonder if its worth welding or just giving the plans to someone
Still, judging from your previous posts, I have more pistons than you at least
I've cracked how to make a digital dashboard by the way, using a couple of multiplexers I can provision for 256 LEDs but using some straight forwards programming with look up tables have the design very flexible. Just need about 100 quid and a couple of months off work now
