INDY BIRD
posted on 22/7/07 at 05:47 PM |
SVA what steering wheel other than sierra?
Got to get a steering wheel do you know which one will pass sva other than sierra as it wont fit my car due to doing paddle shift??????
Or i do have a mountney one but cannot get a pad for it??
sean
iiyama
posted on 22/7/07 at 06:19 PM |
momo team should pass. Dax supply it as an SVA friendly wheel
If its broke, fix it. If it aint broke, take it apart and find out how it works!
graememk
posted on 22/7/07 at 08:10 PM |
i have a couple i lend out for sva if that helps
scoey m
posted on 24/7/07 at 03:14 PM |
Hi
I have 300mm westfield steering wheel for sale with mountney boss to fit sierra column passed my SVA no problems
40 QUID +P+P
If interested
Martin
DarrenW
posted on 24/7/07 at 03:42 PM |
Westfield wheel should be good. If its the same as ive seen before it is well padded.
i used a SWM wheel for SVA and passed. Basically i was told no holes in spokes and correct rads. If you use aftermarket wheel (ie not type approved on
the sierra column) you need to fit collapsible boss (or at least i had to).
