Author: Subject: 12mm ID low pressure fuel pipe
iiyama
posted on 24/7/07 at 05:57 PM Reply With Quote
As topic, need about 16-18".
If its broke, fix it. If it aint broke, take it apart and find out how it works!
jollygreengiant
posted on 24/7/07 at 06:57 PM Reply With Quote
Vauxhall dealers mate:-
part number - 90325858,
description - hose bend
retail - £13.10 (+vat)
mostly straight, but has a short bend formed in one end, about 2 foot in total length.
hope this helps
Enjoy.
iiyama
posted on 24/7/07 at 08:15 PM Reply With Quote
Ta muchly!
indykid
posted on 24/7/07 at 08:23 PM Reply With Quote
or here
it's high pressure, but unless you specifically need it to be thinner wall, it's a fair bit cheaper even with postage.
hth
tom
iiyama
posted on 25/7/07 at 11:51 AM Reply With Quote
Slight change of plan, might go with the stainless braided. I know I dont need to on the grounds that it is the low pressure side of the system, but the first few inches are exposed to to the road, although not below the lowest line of the chassis. Figure it will be tougher if it gets hit by a stone.
Question is this, does this type of hose have any give in it? ie will 10mm ID stretch over say a 13mm fitting?
indykid
posted on 27/7/07 at 02:05 PM Reply With Quote
i'd say it has some, but not that much.
stainless overbraid even less so. if it was a 13mm fitting i'd definitely look for 12mm i/d.
tom
