chrsgrain
| posted on 29/7/07 at 03:54 PM |
hydraulic jack wanted
Having now got the car down off the stands - need a jack to get it back up onto axle stands!
Any suggestions of a sensibly priced one that is low enough to get under a seven?
Chris
UncleFista
| posted on 29/7/07 at 03:59 PM |
I've not found a "locost" one that'll fit under the car, so we drive/push it up onto a brick first (now that's
"sensibly priced" )
Tony Bond / UncleFista
DIY Si
| posted on 29/7/07 at 04:39 PM |
Same here. I have to drive mine onto a plank of wood or similar before I can get my trolley jack under it. You can get very low level jacks, but they
tend to be an absolute fortune.
Sun Tzu, The Art of War
| posted on 29/7/07 at 05:01 PM |
Might be worth checking out your local S/H garage equipment dealers for a British made Bradbury jack . Brought mine new in 1976 and still going strong
, the jacks you get these days are made in China or Italy and won't last 5 minutes. If your car is too low to get jack under make a couple of
"ramps" out of 2x4 .
| posted on 29/7/07 at 05:07 PM |
Bottle jacks are a no-no with a Se7en....
I use a cheap trolley jack and haven't found a problem (but then my ride height is quite high)...
If you can weld why not make a rocker? Its just a bit of sheet metal with a bit of circular tube welded just after the middle and a bit of square
section welded across the other end. You flip it over and put it on the floor- if you make it right it'll sit on the floor with the square
section end held in the air and as you drive up the ramp it'll see-saw around the round section bit, the square section holding it off the
floor. Easy to use (unless you've got a seriously slippery floor, gluing deck tape or wet+dry paper to the circular tube might help) and give
you extra height to get the trolley jack under.....
blakep82
| posted on 29/7/07 at 05:48 PM |
i want to make a quick jack (F1 style) for my truck not sure of the best way though
________________________
neilj37
| posted on 29/7/07 at 05:56 PM |
Would one of these be any use. Its low enough to go under my seven.
http://www.machinemart.co.uk/shop/product/details/ctj1250a-11-4-tonne-aluminium-trolley-jack/path/trolley-jacks-bottle-jacks-transmission-jacks
| posted on 29/7/07 at 06:16 PM |
ive thought about one of those. Its harder for us as the wheels drop more when we lift, f1 cars wont have as much travel in the suspension. I reckon
1.5" should be enough to make the rubber leave the ground though, im sure it could be done with leverage!
blakep82
| posted on 29/7/07 at 06:18 PM |
you can buy ones that give 10" lift, at a price... £160 or thereabouts...
actually, having seen some pics of some on the internet, they shouldn't e too difficult to weld up
[Edited on 29/7/07 by blakep82]
bob
| posted on 29/7/07 at 06:45 PM |
I have a trick with the regular 2 tonne trolley jack is to remove the front two wheels, this takes about 1/2" off the height of the jack.
I've got a spare jack and i'm thinking of doing this and welding a 3mm plate on the front as a skid, this would save wrecking the garage
floor.
Any thoughts ?
NeilP
| posted on 29/7/07 at 07:04 PM |
Got a cheapo Halfrauds 1.5 ton jack and it wont fit under - I use a long piece of timber as a lever to lift the front 2" and then nudge it under
with my foot...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
Catpuss
| posted on 29/7/07 at 09:12 PM |
Yep I've used the Halfords one no probs. In fact I had to use a piece of timber as a shim between the jack and the chassis.
scottc
| posted on 29/7/07 at 09:25 PM |
With the Porsche I normally position the trolley jack infront of the cross member, then lift the car by hand and nudge the jack forward with my foot.
| posted on 29/7/07 at 09:57 PM |
I take the cup thing off my jack and it gets me another 1/2", it's only held on with an R clip and the jack fits under then.
blakep82
| posted on 29/7/07 at 09:59 PM |
how low is the average 7? like, whats the ride height?
