Avoneer
| posted on 31/7/07 at 09:43 PM |
42mm p clip
Can you get them?
Pat...
Mark Allanson
| posted on 31/7/07 at 09:52 PM |
I made my own, only takes a couple of mins with a pipe as a former
darrens
| posted on 31/7/07 at 09:56 PM |
biggest I've seen is 35mm
RazMan
| posted on 31/7/07 at 09:59 PM |
CBS do a plastic covered steel strip that is pre drilled and you can form easily. Go as big as you want.
Raz
bob
| posted on 31/7/07 at 10:01 PM |
Yup i'm sure i got some that big from steves stainless at one of the shows.
Pat i might even have one spare if thats all you need,i'll check in the garage tomorow night.
Avoneer
| posted on 31/7/07 at 10:19 PM |
Actually 2 I need but thanks.
Might have a go at making a couple.
Pat...
emsfactory
| posted on 1/8/07 at 09:06 AM |
Made of what?
i have some big nylon ones, would have to measure for size though.
bob
| posted on 2/8/07 at 11:57 AM |
Pat
Best i can do is a couple of 40mm P clips i purchased from steves stainless, i am thinking they may well get to the 42mm needed if not completeley
closed. (maybe a spacer)
